跳转到主内容
Second of its generation, released in November, 2011, the Sony SLT Alpha-65V is a SLT (Translucent Mirror Technology) camera with a Sony Alpha/Minolta lens mount.
12 个问题 查看全部
SD card can't be inserted
Hi guys,
I think I have ruined my camera SD card slot, the SD-card can't be inserted , when I push it into the slot, it return back without getting in place. even I can't hear any click to let me know that the SD card is in place.
How can I repair this? do I need a new spare parts? any reference parts number?
Thanks a lot
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Did you try inserting it the other way? It will only fit in one way.
这个答案有帮助吗?
得分 0
添加一条评论
Check the slot with another card...it could be a small part of the card has broken off...never force a card into a slot...if it still won't click home...worse case scenario...use a flashlight and look into the gap of the card holder to see if the metal tongues are misaligned...If they are bent out if shape...then you can try Luton Cameras for spares....they usually supply for canon and Olympus but sometimes keep Minolta Sony bits or will direct you to another source...lastly go to eBay and see if you can source a spare and repair Sony Alpha...
I think most Minolta models use the same module for card slot holders.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mhamdani 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 625
