跳转到主内容
雅达利视频电脑系统(VCS)有MOS科技的 6507 CPU ,频率为1.19MHz
31 个问题 查看全部
Sport/Racing Controllers not responding correctly when wheel is turned
Hi All,
Just wondering how to fix the 'wheel' controllers for Atari 2600 systems. Both sets usually have the same problem, eventually they seem to wear out and the buttons will work fine, however when spinning the knob (or wheel), you might get a jitter at best as a response from this joystick.
If anyone could enlighten me, that would be great! Many thanks in advance!!
Mike E
EDM, AB, CA
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
My guess is that the contacts on the wheel have either corroded or been built up with dirt.
Pull the wheel off of its peg, and unscrew the washer holding it in place (a pair of pliers will get it open). Open the back case with a Phillips screwdriver, and pull out the variable resistor. If you look at the underside of the resisitor mechanism, there are four metal tabs. Bend them out of the way, and lift the cover off. Inside are some metal rings, these are the contacts. You can clean them with some rubbing alcohol, or remove them and brush them down with some steel wool to remove corrosion.
Good luck, let us know how it works out.
这个答案有帮助吗?
得分 4
2条评论:
完成的
Thanks for the quick response! I will be out of town for the next couple weeks here, but I will post back once I get the chance to crack these open.
完成的
添加一条评论
添加你的答案
Esso 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,117
