跳转到主内容
修复你的物品
维修的权力
配件 & 工具
数百个光盘驱动器的维修指南。
32 个问题 查看全部
Everytime I put a blank disc in it automatically ejects
I cannot seem to burn any discs due to the Matshita UJ85J Disc Drive automatically ejecting them. But it lets me copy information from a disc to my hard drive.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
2个回答
最有帮助的答案
Sounds like it only ejects the disks when you try to burn something. Try changing the brand of blank disk. Try blowing the unit out with canned air. What is the history of this drive? When did it start doing this? What machine is the drive in? What operating system? What burning software are you using? What steps have you tried to fix it?
这个答案有帮助吗?
得分 1
评论:
Is this a Mac or Windows machine? +
完成的
Another good suggestion which worked for me during burn woes was lowering the speed at which you try to burn the CD's.
完成的
添加一条评论
It is an Apple iMac 4yrs old. It started on Monday evening. Version 10.5.8 and I use Toast Titantium 9. I have wiped the discs, changed the discs and the first 1 worked and the rest just ejected, I have wiped the area where the disc goes in at the side of the monitor.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul Trivett 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 818
