跳转到主内容
修复你的物品
维修的权力
配件 & 工具
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
120 个问题 查看全部
78 mercedes 280E 2.6 m110 I6: difficulties running in the morning
When starting in the mornings will start up fine and idle rough for a 10-15 minutes and during that time acts like the engine is flooding if you try give it gas. What's going on?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
1个回答
The CIS system on the M110 engine uses a separate electronically controlled cold-start valve. It is basically one single fuel injector that sprays into manifold, enriching mixture. Device is controlled by a thermo time switch, which turns on power to the injector. If the injector leaks or runs too long, and overly rich condition exists causing poor idling and greater fuel consumption (poor mileage). Check thermo time switch by unplugging electrical connection at cold-start valve. If rough idle condition persists when power is disconnected, injector is likely leaking or spray pattern is diminished (caused by a dirty nozzle). It is more likely the injector is faulty than a fault of thermo time switch exists.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul severance 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 21
总计 412
