跳转到主内容
7.9 inch android tablet manufactured by Acer in 2013.
32 个问题 查看全部
boots then shuts down and powers off
device shows power but shuts down on its own, behaves intermittantely when reboot or starting up
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I have the same problem with my tablet. There's a permanent solution and a temporary solution; the temporary solution is to unplug the screen via the ribbon cable while it charges for a while, then plug it back in. The permanent solution is to get a new battery. What's happening is the screen uses too much battery before you can do anything, which usually means you need a new battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
paulson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 90
