跳转到主内容
HP ProBook 4320t manufactured in May of 2010.
6 个问题 查看全部
Can't remove CPU heatsink because two of the screw heads are damaged
I replaced the thermal paste on the CPU and Radeon chip in a 4320s a couple years ago due to over heating causing shutdown on boot which fixed the issue.
It's happening again but this time I can't remove the heat sink because two of the screws holding it in place are damaged and won't turn no matter what screwdriver I try. The driver just spins in the head of the screw.
Any advice would be greatly appreciated.
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Have you tried these:http://www.amazon.com/Alden-8440P-Grabit...
Or use a round disc bit to carefully grind a line in the screw with a dremel so the screwdriver will grip?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zayn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 539
