跳转到主内容
Model A1138 / 1440x960 screen resolution
85 个问题 查看全部
won's start up at all, dead
Powerbook won't start up (about 5 years old)... no sound, no light, nothing. I have tried resetting PMU, can't do the PRAM reset... no joy with either of these). I recently replaced the power adapter, but should be fine as is the same model as my old one. Problem started when I left ethernet cable plugged in overnight. The power chord glows amber only, and looks like the battery has no life, but it did have some life before the problem started (would work for a couple of hours without power). I would like help diagnosing the problem and the likely repair cost. Gratefully!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
If you remove the battery from the computer, does the light on the AC adapter still glow amber? If so, that's an almost sure sign of a bad DC-in port, since it should be green without a battery. Especially if it's a darkish amber, and not a bright orangish amber. You may need to replace the DC-in/sound board.
Also, have you made sure you're using a 65-watt AC adapter?
I'd re-seat the RAM as well, and try it with memory in one slot with the other free, and then with memory in the other with the first free (to test for a bad slot, which is very common with these machines).
这个答案有帮助吗?
得分 3
3条评论:
Both are very good answers.
完成的
Agreed +
完成的
+ primo
完成的
添加一条评论
Considering its age you might want to consider replacing the PRAM battery. Some of these older Macs won't work with a bad PRAM battery.
You can try just unpluging the battery first--if your computer boots replace the battery.
Good luck, Ralph
PowerBook G4 Aluminum 15" 1.67 GHz PRAM Battery Replacement
[关联产品丢失或禁用: IF154-094]
这个答案有帮助吗?
得分 1
1条评论:
完成的
添加一条评论
添加你的答案
Kay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,397
