跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
问题已关闭
Communication board heating up & draining battery
My 16GB 1st gen battery would not hold a charge for more than an hour or two in ANY 'active' or 'sleep' mode, even after getting a NEW battery (wifi, push, alarms, music etc. all off.) That's when I noticed the Ipod was becoming very warm. I opened it up and was feeling the various innards to see where the heat was coming from. At first it seemed the heat was coming from the large metal piece dead center of the communications board ( On the logic board repair guide for this ipod please see Picture 3 of Step 6) Then I realized, as I BURNT my finger, that the heat was coming from the collection of little squares next to the big metal plate (by the screw circled on the right) in the same picture. It's possible the heat is coming from something underneath this board or the screw itself (we're working on opening it up further, but have a stripped screw issue we're dealing with.) I was wondering if anyone knows what those little squares are. Any idea of what is causing this issue. Suggestions we can try to fix this problem? I do NOT care if we get the wifi working I just want the ipod to be able to HOLD a charge and obviously something on the comm board is draining it. Thanks all!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It sounds like one of the chips went bad on your logic board which would cause the chips to get very hot and i mean very hot. I have burned my fingers many times repairing ipods. I suggest replacing your logic board and that should also fix your wifi issue.
这个答案有帮助吗?
得分 0
1条评论:
That's a bit heart breaking to hear. For the price of a new board I can get a working used ipod. :( *sigh* And yeah, VERY hot, I burnt myself pretty good. I was hoping it would be an easy fix (although replacing the logic board is easy enough...) I think perhaps I mean "cheap" fix :) Thanks so much for the help Ryan.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,632
