跳转到主内容
Released January 2004. Provides wireless internet for a local area.
2 个问题 查看全部
LED Lights "RED & ORANGE" is stable
hi
i have Linksys WAP54g but its not working try to repair the same
LED Lights "RED & ORANGE" is stable i try to reset it but nothing happen
"GREEN" LED no light no activity
please help
Thanks
San
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
How are you trying to connect, via Ethernet or Wireless?
The red light indicates that power is OK. The orange light indicates that the Ethernet connection is OK. No green means that the Wireless is not turned on.
If you are trying to connect via wireless have you gone into the router's user interface and turned on the wireless?
To access the web-based utility of the Access Point, launch your web browser. In the Address field, enter the Access Point’s default IP address, 192.168.1.245
The login screen will appear. Leave the User Name field blank. The first time you open the Web-based Utility, use the default password, admin.
Once into the router interface you can set all the parameters necessary to set up your wireless router.
To initially get the green LED to light, you need to go to the Wireless Tab in the Router interface and change the mode option from disabled to mixed.
Here is a link to the User Guide for your router. It will help you to set up your router.
http://downloads.linksys.com/downloads/u...
这个答案有帮助吗?
得分 3
添加一条评论
Let's try these options to fix linksys router orange or red light problem.
1. unplug the router and connect your modem directly to your laptop. now try to access the internet.
If you can't access the internet on laptop. it's a problem from your internet service provider.
2. if you can access the internet via modem, but not from the router. you need to check the connection between router and modem.
3. Try to powercycle your router and modem for once.
4. Disable the DHCP server and configure the router with Static ip connection.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sanjay Tikoo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,570
