跳转到主内容
The 1999 Chevrolet Malibu is part of the fifth generation (1997-2003) manufactured by General Motors. This is the first smaller, front-wheel-drive Malibu that General Motors put back on the market after the Malibu line was temporarily discontinued in the early 1980's.
55 个问题 查看全部
Overheating and question about the transmission fluid pan
1998 Chevrolet Malibu LS 3.1L
I'm having trouble with my 98 malibu overheating sometimes it will then sometimes it will stay At 3/4 on the gauge I've already replaced the thermostat and also have a question about the transmission fluid being able to check it and how to tell if it's low or needs changed
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Where is the transmission refill located?
完成的
添加一条评论
4个答案
已选择的解决方案
Lee, since TJ. is offering to take care of your transmission question, I will take a stab at your overheat condition. There may be air in the system, which will have to be bled out, so system can function properly.
Check the attached links,instruction and guides on more reason for engine to overheat, Good luck.
https://www.youtube.com/watch?v=ad9u8jAD...
http://www.auto-repair-help.com/auto_dia...
这个答案有帮助吗?
得分 3
添加一条评论
I need too check on somethings first, I do believe that they did away with the transmission dip stick in that year. The dealerships have the dipstick as a tool. I made one so that the guys the install the transmission can use it. We have a trick for doing it without it. I need too know if you can pop the hood and look down at the top of the transmission and see if there is a yellow cap you can unscrew? I will get my computer out tomorrow and pull up the information for you. But check that for me if you can.
Thanks, TJ
这个答案有帮助吗?
得分 1
1条评论:
I have a 3.1 malibu 1997. do these have a dipstick at all for the tranny fluid?
完成的
添加一条评论
A possible gasket head problem, white smoke,little water from exhaust pipe, its seem oil and water mixs
这个答案有帮助吗?
得分 0
添加一条评论
You can check the level through the overflow tank shown on the check fluids page. Careful if the engine is hot? Best wait until it is cool. Leave the hood up to cool faster. Later try removing the cap but SLOWLY and if there are no steam coming out.
The overheat problem I had was related to a coolant temp sensor, on the 3.1 it is on the driver's side. Under the throttle body control. Replaced it and the fans don't run until the engine is hot.
When the engine now heats up on mine, the car still overheats and because the engine is hot and the radiator is cool gives a clue. If there has been coolant loss and a refill, it might be due to air in the coolant lines, and so don't be so quick to guess it is the thermostat. On the 3.1 they are a b....h to change. But hope that give you ideas. Also google for the replacement of such on google u tube and watch the movies. That is good. OK? Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 628
