跳转到主内容
许多尼康单反和点击拍照的傻瓜机的修复指南。
1461 个问题 查看全部
Nikon D3200 Buttons not working
My Nikon D3200 menu, playback along with buttons 7-9 are not working. Literally nothing happens when I press these buttons. There is not a reset button on this camera. Looking for advice to help me fix this problem. Any suggestions?!?
Desperate
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
The first way to fix this hardware issue is resetting. To reset you camera :
  1. Press [Menu] button.
  2. Select the “Shooting Menu”
  3. Scroll through the options until 'Reset Shooting Options' is highlighted.
  4. Press OK.
  5. Highlight 'Yes' and press OK again.
  6. Repeat this for the “Setup Menu”
If reset will not fix hardware issue then go to Nikon D3200 Manual for help.
这个答案有帮助吗?
得分 1
1条评论:
my nikon d3200 Modes changing dial is Rotating flawlessly without changing any mode even that vibration of mode changing is also not there it is rotating like a a cap
完成的
添加一条评论
there is no guide for replacing the button ribbon cable on here but you can follow this guide to access the ribbon cable and replace it..
Nikon D3200 LCD Screen Replacement
这个答案有帮助吗?
得分 0
1条评论:
hi
my camera is Nikon D3200.
In My camera Scroll Button doesn't work.
it may works when i hold AF Lock button.
can you fix this problem please.
thanks,
Gowri shankar
完成的
添加一条评论
添加你的答案
Felicity 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 6,779
