跳转到主内容
The Fujifilm X30 is a point and shoot camera with a 3.0 inch LCD screen.
12 个问题 查看全部
问题已关闭
Why are the pictures coming out blurry?
Recently while taking photos at the OC Fair, I noticed the photos I was taking came out unfocused and blurry. I thought the problem would go away after awhile, but it only got worse. I tried wiping the lens clean of dirt since it was windy at the fair, but that did not help. Please help me. I've run out of things to do and I'm getting desperate.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Jay,
You should check to see if there's any visible damage or scratches to your lens. I am guessing that this is the reason your camera is not focussing. If you notice damage, then the lens will need to be replaced and you can refer to this lens replacement guide . If you don't notice any damage, then the problem may be in the motherboard and you can look at this motherboard replacement guide. I hope this helps fix your camera's problem!
Fujifilm X30 Motherboard图片
指南
Fujifilm X30 Motherboard Replacement
难度:
困难
1 hour
Fujifilm X30 Lens图片
指南
Fujifilm X30 Lens Replacement
难度:
中等
1 hour
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 947
