跳转到主内容
The Panasonic LUMIX DMC-LX100 is a compact digital camera with 12.8 MP resolution, 4K HD video capabilities, and Wi-Fi access. It was released in November 2014.
23 个问题 查看全部
How do I deal with a cracked screen?
I dropped my camera on the screen side and there is a large crack running down the middle of the screen as well as some other smaller cracks around it. The rest of the camera is still working fine so I figured it was still usable. The problem is that every time I take a picture, I cannot see it around the crack so I don't know if it is a good picture. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
Hi Sydney,
Thanks for the question! Since the rest of your camera is functioning as it should, it seems like you just need to replace the LCD screen. After doing so, your pictures should show up as normal. Please refer to our LCD screen replacement guide to switch out your screen and get your camera working as new!
这个答案有帮助吗?
得分 0
添加一条评论
Dear Dye, if you can't replace it's LCD display, just use the viewfinder instead. You can wait, too, to use the LukiLink gadget. See it on: https://m.dpreview.com/news/1746775569/l....
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sydney Dye 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 818
