FoxPro version 9 issue
I have a FoxPro file with a corrupted FPT file. Can't remember exactly but I get error something to the effect that the FPT is corrupt of missing. The DBF otherwise seems okay. FoxPro version 9. How can I repair this?
"Not a table" means more serious problem than TABLEVALIDATE can fix obviously. Also when DBF recovery fails the problem can be critical (if you have the DBF recovery which supports your DBF file format).
You should look at the DBF header via some hexa editor. You may even use the one from VFP:
DO HOME() + "Tools\HexEdit\HexEdit.app"
It will ask for a file opening so please select your DBF and post first two lines here or look at the DBF structure description in the VFP help.
First two lines (in hex editor) contain the file type, number of records, record size, last update etc. "Not a table" means the first byte was not recognized as valid DBF file marker.
Additional lines contain column descriptions each one in 16 bytes.
More info: http://msdn.microsoft.com/en-us/library/...
Second easiest fix is use DBF Recovery Toolbox or some other applications. Search in Google. http://www.oemailrecovery.com/dbf_recove...
这个答案有帮助吗?
Refer to the following thread for some possible solutions.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 87
