跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Faulty home button, doesn't work
My friend has an iPhone 6 which I refused to fix because of the home button issues. His home button doesn't work at all so needs replacing but can't do that because when it's updated it will get error 53.
The phone is under warranty but had a screen replacement
I could swap an original lcd back on and claim under warranty
Failing this, does anybody have any alternatives or any other way?
is it possible to swap the components on the flex cable onto the replacement?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
There is no alternative, original home button only.
They may be having issues with home button because of the extended cable under the shield, try replacing that first, because if that gets damaged it causes issues with the home button. If that fails, then only thing you can do is try and put an original screen on, clean up all the inside to make it look like it hasn't been opened, they may or may not replace it.
这个答案有帮助吗?
得分 1
添加一条评论
Well that's not exactly true. You need to keep the original, unworking home button, for when you do updates. As long as the original home button is in there, it shouldn't get error 53. The rest of the time you can use the after market button
这个答案有帮助吗?
得分 1
2条评论:
Yes I know that but that's not really fixing the issue, is it? I'm not going to put a button on the phone that they can't update etc. It would require constant support from me and is not worth doing
完成的
Well the customer needs to weigh the pros and cons of the situation. How much is the phone worth? If it gets error 53 it's bricked. How much would you be willing to charge to put the old button on and update it for them?
完成的
添加一条评论
i'ts posbile but even if ou menage to do it, nobody knows how long will it work
这个答案有帮助吗?
得分 0
添加一条评论
Error 53 is a vestige of history. It is no longer a problem since Apple released iOS 9.2.1. As long as you're not running iOS version 9.2.0, you shouldn't see error 53. See https://techcrunch.com/2016/02/18/apple-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James Carter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 446
