跳转到主内容
加入维修社区 - 创建账户
Released on October 1, 2013 the BLU Studio 5.5 is an unlocked Android smartphone with two model types being the D600 (single SIM) or D610 (dual SIM).
Why does my phone keep on freezing?
This started recently when I formated my phone. Since then its been freezing after like every 10mins and says messages or launcher won't work. I try rebooting it but never helps..... Am already tired with this phone
Please help fix it for me!! Its not the best situation to be in
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
2条评论
Even with the hard reset, it's still freezing. Both the Vivo 8 and the Vivo 8 L.
It's really frustrating
完成的
I have been using Grand M for almost a year and half but, the phone is useless. Keeps on freezing. I formatted it so many times but still the same problem is occuring
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
You need to hard reset your phone.
Be aware a hard reset will erase all your downloaded apps and user data. It will restore the phone to a factory default condition. It will be like when you first bought it.
Before you perform a hard reset, back up your data using the phone's backup feature.
Note: If, after performing a hard reset you restore your phone to what is was before you did the reset, using the backup you made, it may re-introduce the problem that you were having, e.g. if a downloaded app was causing the problem.
If you can, ensure that the battery is charged before you perform a hard reset. Also do not have the charger connected when you perform a hard reset.
Here is a link that shows how to perform a hard reset. (it is not for your particular model but the procedure is the same for your phone)
http://www.hardreset.info/devices/blu/bl...
这个答案有帮助吗?
得分 2
1条评论:
I have a blu smart phone mini and it is frozen i tried resetting it taking out the battery but nothing works i can only turn on my notifications and thats it how do i fix it
完成的
添加一条评论
添加你的答案
vanessa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 5,178
