跳转到主内容
The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
64 个问题 查看全部
exhaust smokes when starting engine
2000 Camry - V6
friend swapped engine out with a ebay engine, lasted couple months
sat for almost 2 years after engine swap, it didn't survive
had a shop fix the alternator
now the cars exhaust smokes every time no matter time of day or every time it starts through out the day.
Once in a great while after putting oil, it'll stop a little, but smokes again.
Engine light stays on
Please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What color is the smoke?
完成的
添加一条评论
1个答案
已选择的解决方案
Well if it's a white smoke on just startup it most likely the valve seats that are leaking a little.as the car sits overnight or for a few hours. A valve job will fix this issue (probably around 600-700 @ shop
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
hawaipinay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 194
