跳转到主内容
The HP Pavilion dv2000 Notebook PC is an entertainment based PC produced in 2007.
23 个问题 查看全部
My HP Pavilion dv2000 isn't detecting any wifi signals.
My dv 2000 isn't locating any wifi and the wilan light is not coming on,help pls??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Does this have Vista on it? If so, youll need to download the newest wifi driver and update it. I have seen this issue on several Vista based laptops. Also, follows these possible solutions.
1. Some HP's have a wifi switch on the side or near the front. Flip that on. These can be turned on accident.
2. See if there is a function button to turn on your wifi. For example, FN and F9 to toggle wifi on and off.
这个答案有帮助吗?
得分 0
添加一条评论
In the corner, click the wifi and then instead of manual, change it to 1 hour. Then in one hour it should detect wifi.
这个答案有帮助吗?
得分 0
添加一条评论
If you look near the ports under the mousepad there is a wireless switch make sure it is blue
Install the WIFI antenna drivers
Good luck:)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
william 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 274
