跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
138 个问题 查看全部
Why does steam wand leaks water when valve is closed?
Can you show or tell me how to fix a steam wand valve that leaks a stream of water when brewing? I have it completely closed and water still steams out.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Refrence the Starbucks Barista teardown to get inside of the machine. At step 8, loosen the 2mm hex screw on the steam valve knob and you should be able tighten/close the steam knob more than before. Re-tighten the 2mm hex screw, reassemble the machine and test it. If this doesn't solve the problem you may have some calcium blocking the valve from closing all the way, which a descale should take care of.
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
添加你的答案
jeanne lester 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 24
总计 7,423
