跳转到主内容
An economy SUV by Mazda, not the greatest sport utility vehicle in the world, just a Tribute. Made in the USA by Ford Motor Company. Simply a rebadged Ford Escape.
17 个问题 查看全部
Where is temperature sensor located?
Where can I find the temperature sensor on my 2003 Mazda Tribute 4 cylinder engine
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Where is the heat sensor located on Mazda tribute 2003-2007?
完成的
where is the location of thermostat switch sensor of mazda tribute 2001 and to remove
完成的
Where is the heat sensor located?
完成的
添加一条评论
2个答案
最有帮助的答案
@chasp you did not tell us exactly what temperature sensor you are looking for. It might also help if you tell us why. The CTS (coolant temperature sensor) is screwed into the thermostat housing near the top radiator hose.
这个答案有帮助吗?
得分 2
1条评论:
Yes it's the coolant temperature sensor
完成的
添加一条评论
under the intake manifold on the back of the alternator, better to remove the alternator so u can see the coolant temprature sensor.✌
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chas Plunkett 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 72
总计 7,279
