跳转到主内容
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136 个问题 查看全部
Is the charging port replaceable for my GALAXY TAB 4 7.0
I am hoping for some direction on repairing the charge port on a Samsung Galaxy Tab 4 7.0 MODEL #SM-T237P. Is this part soldered? Also is the charge port the same for all of the tab 4 7.0 model's???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
Hi,
The part that you want (it is the soldered on type) is available on Ebay http://www.ebay.com/sch/i.html?_from=R40... I do not know if they are the same for all Galaxy 4 7.0 models
Here is a link which shows how to replace the battery in your Tab. It is handy as it shows how to open your Tab. At 1:46 minutes into the video you can see the charging port (which is soldered on) on the right hand side of the Tab, as seen).
https://www.youtube.com/watch?v=byR1_wgN...
Here is a link which shows how to remove /replace the charging port on a similar model Tab (not the same model but hopefully good enough to give you an idea on how to do it).
https://www.youtube.com/watch?v=4mcXJVbK...
Hopefully this will be of some help.
这个答案有帮助吗?
得分 3
添加一条评论
Can I fix the port on my galaxy tablet four by myself all
这个答案有帮助吗?
得分 0
1条评论:
Hi,
It is not a job for novices. You will need SMD soldering expertise and tools to perform the repair. You can cause more damage if you don't know what to do.
It may be better if you take it to a reputable, professional mobile phone or laptop repair service and ask for a quote.
完成的
添加一条评论
You can get the charging port here. Also here is a YouTube video about how to repalce a charging port.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
amber hyatt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 15,213
