跳转到主内容
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
Why won't apps download on my device?
Ever since yesterday I haven't been able to download anything from the app store, anything I try to download will freeze at anywhere from 80%-96% and then just stops. I have no idea why. My only guess is there's a problem with the device and I need to reset it to factory defaults.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 17
15条评论
I have Not been able To Download Any app on my Samsung Phone. I would Press 'Instal' Then it would Go to 100%, Then While it saying installing, It Just freezes and Says Installing Forever, I Think Its beacause My phone is Working Bad, Please Tell me how to fix This Issue, I want to Download this app Before Tonorrow Please and Thank You :)
完成的
How to I solve my problem I cannot download the video pictures
完成的
I have a similar problem on my Samsung Galaxy Tab E, but it's where the apps are stuck saying "Download Pending" then never begin downloading. Any help would be nice.
完成的
did anyone solve this please?
完成的
I have a Samsung tablet s4, and it wont let me download you tube, others apparently are fine, it's just this one??
完成的
显示更多的10条评论
添加一条评论
2个答案
已选择的解决方案
Hi,
Here are two options you could look at.
1. Have you tried updating the Google Play Store app?
Open the app, tap Settings, scroll down to Build Version, tap to enter. If there is an update option select it and allow it to update. Try to download an app and see if it works.
If it says it is already up to date, try the following: From Main Menu on tablet go to Settings > Apps > swipe right to All > scroll down to Google Play Store, tap to enter, tap clear data. Try to download an app. Hopefully this may help you.
2. Not quite sure where it is located in your Tab but go to Menu > Settings > Apps > swipe right side to ALL Apps, then scroll down and find Download Manager. The Apps are listed alphabetically, with working apps first then disabled apps.
Tap to enter Download Manager. If there is an Enable button tap it then try to go online.
If it says 'disable' tap to disable, then clear cache. reboot Tab then navigate back to download manager and enable it as above.
See if you can access the internet with your browser then try downloading an app from the Play Store.
Hopefully this is of some help
这个答案有帮助吗?
得分 5
3条评论:
Sadly neither options worked. When I went to clear the cache on the download manager it wouldn't clear it. But I did everything else and it still paused at the same percent as it always does.
完成的
Hi,
One last try. Try going 'offline' with your phone go to Menu > Settings > Wireless and Networks > more > Mobile Networks > Data Connection, tap to enter, select off. This only disables your data connection not your phone. Then try clearing cache / data in download manager. Reboot the phone. Make sure download manager is running, turn data connection back on then try downloading app.
If this doesn't work you were probably right. Back up your phone and then perform a factory reset. Then restore your phone. Hopefully this will resolve your problem
完成的
Jayeff your instructions worked perfectly thanks so much now I can read my book
完成的
添加一条评论
I disabled my play store and enabled it again, clear all cache and after that it got downloaded.
这个答案有帮助吗?
得分 0
1条评论:
How do i clear cache and data
完成的
添加一条评论
添加你的答案
TheDiceman91 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 18
总计 78,135
