跳转到主内容
Model A1051 / 4 or 6 GB hard drive
90 个问题 查看全部
Why doesn't my iPod sync with iTunes via USB 2.0?
My iPod mini has recently suffered from battery issues, but it still charges. By battery issues, it has bad battery life. If it has a full charge, the battery will typically lower to 25% within a minute. I will replace the battery soon, but I don't think that is the cause of my problem. When I plug my iPod into my computer, it doesn't show up, and doesn't sync. The source of the problem is not my computer, as I have tried to sync the iPod with a PC running Windows 8.1 64bit, an iMac running Mavericks, and a MacBook Air running El Capitan. The iTunes versions are up to date on all operating systems. On some occasions, iTunes has given me an error message which told me to restore my iPod. When I selected the option, the iPod then ejected itself before anything could happen. I suspect the problem could be with the logic board. I am fairly new to these components, so any advice is helpful.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Have you tried connecting with a different cable? This could be the issue as well.
这个答案有帮助吗?
得分 0
1条评论:
Yes. I have tried using the original 30-pin charger that came with the iPod. I have also tried using a newer 30-pin from a 4th gen iPod touch, as well as a 3rd-party 30-pin charger. None of these have worked. I can only charge the device, but syncing doesn't work... Thanks for the suggestion though. :/
完成的
添加一条评论
添加你的答案
Austin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 128
