跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
Did I destroyed the flex cable?
Hello, today I tryed to replace the battery from my iPhone 5S. The battery was really hard to loosen because of the two glue strips. Now I'm not sure, if I destroyed the flex cable for the the volume buttons. Here a picture:
I didn't turn the phone on, cause I'm waiting for the new battery. What do you mean? are the scratched places bad or not.
Iceberg
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
There is no way for us to say for sure if the cable is damaged to the point it no longer works - you have to turn on the phone and test everything out.
That cable controls: The mute toggle switch, volume up/down, the power button, the vibrator motor and the rear flash.
I would give it a 75% chance that it still works.
这个答案有帮助吗?
得分 3
1条评论:
Thanks for your answers
完成的
添加一条评论
Looks damaged to me, try turning it on and checking, just dont expose any metal to the open scratches.
For the future, use the pull tabs at the bottom and the adhesive just slips out from under the battery. 0 pressure needed.
这个答案有帮助吗?
得分 1
3条评论:
Hey Jake, thanks for your fast answer. Do you know, if the probable flex cable is broken, do I see the iTunes logo or does the iPhone not recognize it and I can start it but can't use the volume buttons?
完成的
There is no (or very slim) chance of damaging the phone by turning it on - if that was what you asked. It only controls the switches I have mentiond in my comment below - so if it is damaged, they will simply not work - the phone would start up fine.
As the flex cable controls the power button, there is a chance that the phone will not power on when you try. In this case, try to plug it into a charger, as this will turn on the phone too.
完成的
Unless the connection shorts with metal, you will be fine. Just try it out.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 119
