iPhone housing, worth anything?
I have like 50 iphone housings. probably not worth anything but you never know. anybody got a use for these things or shall i throw them?
they are obviously used and replaced due to a defect so not fit for sale
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
If the housing is in at least good condition it can be worth something.
Some sellers will put all the internal components into a new set of housing, along with new battery and screen to essentially refurbish the iPhone. These can then be sold on eBay as "Seller Refurbished" for example.
My iPhone 5C is seller refurbished and the battery, entire display assembly and housing were all new.
So if I were you I'd pick out all the ones in good condition and give it a ago selling them. You might not get much, but I suppose it'd be better than throwing them away and getting nothing.
评论:
I replace housing because it's got a dent or bent or bad condition so definitely not worth reusing. Just scrap metal really
由 James Carter 完成的
You can recycle it. No body really wants them because refurbishing them is not worth the time.
由 Jake 完成的
Ah, if they all have dents or similar in them then best off disposing of them.
由 August Williams 完成的
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 65
