跳转到主内容
The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
103 个问题 查看全部
How to remove SIM card from slot without the slot tray?
I accidentally put the Sim card in without the tray. Tinkered with it a little, but not ready to start trying crazy methods just yet.
Would you suggest a repair kit on this kind of phone or is it simpler than Alcatel tech support makes it out to be?
(note) Tight budget after purchasing the phone. Repair shop would be last resort.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
There is going to be some force of the pins pressing against the board, but if you tap it with some force it should fall out. Try tap the phone on its side allowing the sim to fall out.
You can also open the phone(not that hard at all) and access the logic board. The Sim card reader is on the underside of it. You just need a clothes pin etc to push the sim card out through the little opening holes.
这个答案有帮助吗?
得分 0
添加一条评论
I fixed it!! A little metal super glue on the end of the slot tray and pull slowly. Loctite ultragel is what I used. Bam!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,359
