跳转到主内容
加入维修社区 - 创建账户
无线连接并控制您的苹果电脑。
spacebar doesn't work not
spacebar stopped working. no spills, not a hardware issue. when spacebar is pressed spotlight comes up this happens without the command spacebar being pressed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Check your command key. It is possible that something is pushing down on the button in between the key. If not then check your Bluetooth settings and replace the batteries of the keyboard to see if that may be a problem. If possible try using another keyboard and see if it gives you a problem with the space-bar, if so then it could be a software setting, maybe in accessibility settings. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
faedra james 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 35
总计 6,596
