跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
No power after water damage repair
Dear all,
Samsung Galaxy S6 had been dropped in water - I did the usual clean and replace battery but still no power and no life from the usb connection.
The board looks good, although I havn't disassembled the daughter board as I'm expecting the device to at least vibrate once a good battery is connected to the main board.
Any ideas/advice?
I've got a daughter /dock connector board on order but I'm wondering how I can test/identify why no power is hitting this phone when all seems well?
Thanks!
Will
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
By usual clean what do you mean? A proper water damage repair cleaning can be quite different than the standard cleaning methods, there is likely some underlying corrosion under any EMI shields that might be prohibiting the device from functioning. You could also (likely) have blown some fuses that disallow a boot.
这个答案有帮助吗?
得分 1
3条评论:
Sorry, I mean a 99.9% isopropyl bath and brush after removing all components and emi shields (except the daughter board).
I couldn't see any obvious damage to any fuses or capacitors but is there any test I can perform to detect any possibilitis?
完成的
I have very limited knowledge on microsoldering but you could use a multimeter to check the resistance of components and identify where the short is.
完成的
you have to get out the microscope and examine the board carefully. pay close attention to the battery connector plug area on the motherboard. Look for any signs of corrosion. You can also try changing out the power ic (there are 2 that commonly fail, youtube video by deep fix shows replacing one of them)
完成的
添加一条评论
添加你的答案
Will 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,195
