跳转到主内容
The Maylong Mobility M-270 is a lightweight tablet with a 7-inch screen.
4 个问题 查看全部
Tablet stuck on boot screen with a red triangle in belly.
I have a m270 and it is stuck in a boot screen with the android man laying on his back with a stomach flap open in the middle of that is a red triangle with an exclamation point in the middle. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
pictures? so i can see what you mean
这个答案有帮助吗?
得分 0
添加一条评论
My tablet is stuck showing the little Android
这个答案有帮助吗?
得分 0
添加一条评论
Despite this being over a year old, I'll still answer it. The device needs to be wiped and the firmware needs to be re-flashed onto the device. I was able to repair a few units with this. The only problem is now, since the Maylong has folded and is not longer in business, the firmware download link is no longer active.
If you were able to do a search and find it, there are two files that can get loaded directly onto a blank micro sd card, and put into the unit before powering on. The device will load the files, wipe the old firmware, and install the new one.
这个答案有帮助吗?
得分 0
1条评论:
I have a apk file, just need instructions on preparing the sd card for install.
完成的
添加一条评论
添加你的答案
Markiese Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 372
