Touch ID Button glass cracked - repair w/o loosing fingerprint feature
Is there a way to just replace the glass on the home button? The Touch ID sensor does not work due to the cracked glass.
No it's not possible, the sensor chip is thinner than human hair and extremely brittle. To make the matter worse, the chip is glued to the button crystal so there is no way to remove it without breaking it.
这个答案有帮助吗?
Thanks because I knew it could be repaired on iPhone 8+ but I was thinking because in my case with cracked button glass I was Not able too repair touch id.
you are always right n you are here :)
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 440
