跳转到主内容
加入维修社区 - 创建账户
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
front camera doesn't function, rear okay?
I replaced the LCD, Digitizer(magnet dropped on top.),. The Cable for, power, volume, mute (found pinched and ripped in half [I blame the corner at/where the cable folds down and around the front camera, it's sharp I put elec-tape small piece] helps.
Okay. My Front Camera stopped working.? when I switch from rear Cam to front Cam? The rear Image freezes? The front Cam, wont even show anything? switch back to rear and Okay?...
I took it apart , Replace with a new Cam?, Did a Software update, Same result,!.
Help help help, I'm stumped??. Maybe MB? Front Cam?
LJ.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Make sure the rear camara is securely connected to the Interconnection Board. The interconnection board can be damage from prying on the conectors at the camara area or the connection for the power,volume, mute switch. The componets are very small and you would need a micro scope for inspection. The front camera could have been damaged also when removing the digitizer / lcd.
这个答案有帮助吗?
得分 0
1条评论:
The Items mentioned, after inspection were replaced, just to be on the safe side.
完成的
添加一条评论
添加你的答案
ljserrano2000 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 94
