跳转到主内容
加入维修社区 - 创建账户
Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
My wifi signal shows I'm connected but...
My wifi connection shows I'm connected but I'm not able to connect to websites. Google shop. Youtube... keeps saying retry again, please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
Hi,
Check the following:
Not quite sure where it is located in your Tab but go to Menu > Settings > Apps > swipe right side to ALL Apps, then scroll down and find Download Manager. The Apps are listed alphabetically, with working apps first then disabled apps.
Tap to enter Download Manager. If there is an Enable button tap it then try to go online.
If it says 'disable' tap to disable, then clear cache. reboot Tab then navigate back to download manager and enable it as above.
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
A device that supports wifi can say it's connected, but it doesn't mean you'll be able to browse the Internet, or use applications that require Internet connectivity.
A device could be connected to the router, in which case the device will say connected but the router may not be connected to the Internet. The first thing I would try is restarting your router and modem. Be sure to leave them off for a good few seconds when turning off.
If this doesn't fix the problem, another thing I would try is restarting your Nextbook. Or perhaps disconnecting and reconnecting to your wifi. Something I have tried myself in the past that's worked on Windows OS, is forgetting the network completely, and then reconnecting. But note that this means you'll have to type in any details to connect to your wifi such as the password.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
edillharris65 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 9
过去 30 天: 17
总计 7,183
