跳转到主内容
修复你的物品
维修的权力
商店
This is a touch-screen controller associated with the Wii U video game console. It was released on November 18th, 2012, and available in black or white. Model number: WUP-010(USA)
69 个问题 查看全部
Broken Ribbon Clip and Has My Brand New Screen Just Died
So I was replacing my Wii U GamePad's LCD screen (long story) and I was golden, everything was fine until I broke one of the small ribbon clips that holds one of the digitizer ribbons in place. So I was finding a solution online like anyone would do and the screen worked if I held the ribbon in place. So most people were saying hot glue but knowing that once I glue something its not coming back up I first tried to find something to hold it in place while I apply the hot glue but next I tried holding the ribbon in place the screen wouldn't turn on. I'm scared at this point that I'll have to buy a new screen to replace the replacement. Someone please tell me I didn't kill the screen. Also it still works as a touchscreen I just can't seem to get the screen to work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Dont glue or solder it...use white / blue tak... see the answer below!
完成的
A solution I saw in a US post was to use a strip of paper over the end of the ribbon and then secure the joint with masking tape. Claimed it would work for a few months.
完成的
添加一条评论
2个回答
最有帮助的答案
Position the ribbon cable onto the conector and then use Use white tak...its like blue tak but kind of sets harder!...to keep the cable pressed down.
This worked for my one!
You might have to try a couple of times before you get it to work!
See my YouTube video on this for help!
https://m.youtube.com/watch?v=mNbxeLlpaO...
http://www.amazon.co.uk/WHITE-TACK-BLUE-...
这个答案有帮助吗?
得分 1
添加一条评论
I take it your screen didn’t die then in end or did it still not work? I’m having this issue too but with the screen staying black since I purchased it, it could be already dodgy screen or the ribbons are not correctly placed so it just shows nothing but still operates!!
i will be trying this white tax solution it makes sense aswell
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rare World Studios 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 9
总计 624
