跳转到主内容
Liquid Damage to Power Port Side - Can I repair this?
While sitting on my bed, drinking a beer it tipped over and flooded the power side of my MacBook Pro.
I tried to cut if off immediately, but it would not power down. I turned it over to drain it out. After that I put it in a huge bag of rice hoping it would draw the moisture out.
After sitting in the bag of rice for weeks I tried to connect it to the power cord. Got nothing. I thought there was no way it could be repaired. It has been stored, (climate controlled for the past year).
I opened the back today and can see there is slight build up of mold spores on the board and inside of cover I removed.
Is there any way I can repair this myself?
Which parts and tools will I need to purchase?
I have taken a basic computer class in which I took apart and re-assembled a PC. I know this isn't the same, as I'm working with damaged parts, but I'm not afraid to try to repair this myself, (if it's possible to do so).
Help me please with probability of repair, parts and tools needed, please.
Thank you,
Criss
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Whoever came up with the idea of telling people to put all their electronics in a bag of rice has to be laughing right now. That's everyones explanation who knows nothing about electronics.
You need to take the board out and soak and or scrub it with 99% alcohol or 91% if that's all you can get .
Then see what your working with. YOu actually made it worse leaving it sit in the bag .
这个答案有帮助吗?
得分 2
3条评论:
The board could have all sorts of electrical issues start with the cleanup , then unless you have basic electronic knowledge reading schematics as well as soldering your gonna need to find a shop that repairs Apple laptops.
完成的
Ugh and thank you John. I bought a small set of screwdrivers, but some appear to be "star" head screws. Any tips on where to buy tools to removed the board?
Thanks again
完成的
Those are torq screws home depot will have precision torq set.
完成的
添加一条评论
添加你的答案
Criss Ann 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 87
