跳转到主内容
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 个问题 查看全部
Lcd connector problem with lCD
Hi,
I recently aquired an iPad mini, however the screen on it stopped working. it still connects and makes sounds. When I opened it up both the lcd connector and flex had a small hole where a few pins should be and there seems to be black soot coming off it as it has been burned.
Could anyone tell me what this is and if it is repairable by changing lCD and the FPC connector.
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
It sounds like someone tried to replace the FPC connector before. The plastic of the connector and the epoxy on components on the board around the FPC connector will blacken and turn sooty if overheated, eg. with a hot air station. Replacing the FPC and LCD may be required to fix it, but you may have other issues as well. The most likely one that would be caused by a short is a dead backlight circuit - very, very, very common on Mini 1s and 2s. That would cause it to seem like the screen is dead but careful examination in the dark would find that the LCD is on but extremely dim (no backlight). So check that first just in case the FPC isn't the problem. Repairing that is much easier than the FPC replacement.
FPC replacement really requires some sort of optical magnification to ensure the pins are lined up properly, and then to be able to check that each pin is soldered to the pad. The procedure is basically:
1. Disconnect the battery! If the backlight circuit isn't damaged already it will be with the slightest wrong move. Disconnecting the battery prevents this.
2. Add generous amounts of a good electronics flux around the old FPC connector, but try to keep it away from other components to avoid lifting them.
3. Use aluminum or copper foil tape as a heat reflector on other components, exposing only the FPC. You can find aluminum foil tape at any hardware store that sells metal ducting.
4. Heat with a hot air gun set at around 260-300C while lifting up the FPC connector. Use a small nozzle and moderate airflow to avoid overheating the board or desoldering other components. Use sharp tweezers or an X-acto type knife to lift the FPC.
5. Clean the pads until they're spotless using new flux (regularly cleaned off with isopropyl alcohol) and desoldering braid.
6. This is the tricky part. You need the new FPC to sit flush with the board so that all pins will make contact, but you also need solder on the pads obviously. There are 2 ways of doing this. The "correct" way (I say "correct" because it's how it's done at factory) is to use solder paste applied carefully in small amounts on the pads. The suspended solder balls in the paste will allow the FPC to sit pretty tight to the board when placed. Then you heat and once the paste hits the melting point surface tension will pull the solder to the pins and the pads. The other option is to carefully apply as-close-to-equal-as-possible amounts of solder to each pad, verifying that the quantities are the same under a microscope or similar. You don't need much. Once it's looking good apply a very thin amount of flux, align the FPC, and heat the solder while using tweezers or similar to keep a slight amount downward pressure on the FPC. Once the solder melts the FPC pins will drop down to the PCB.
这个答案有帮助吗?
得分 1
1条评论:
Hi, thank you for your answer I really apreciate it. It certainly seems that way, the spot is such that it looks like a hot pointy object was pressed against the connector however there is similar damage to the flex as well so I'm not sure how this happened, a few metal components directly above the connector extremely close to it seem to be damaged also, are these the backlight components?
完成的
添加一条评论
添加你的答案
israr7862013 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,110
