跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
Touchscreen doesn't work after replacing digitizer
Hello,
I replaced the digitzer on my iPad Air as the screen was cracked pretty good. It took a long time to get the screen off as it was more like shattered in some places. After i put the new digitzer on, bought off of this website (not a cheap ebay knock off), I didn't seal it with the adhesive as i wanted to ensure the touchscreen worked properly first.
So i carefully put everything into place and nothing happened. i double checked my connections and tried again and nothing. However when i did move the screen to the open position, as i was going to recheck the connectors and cables again , it reacted as i was just barely swiping the screen when it's locked.
Is the digitizer bad? Are my cables hosed? What did I do wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I heard other people having similar problems with cables being bent and unbent. Sorry, not sure what much else to say.
完成的
添加一条评论
1个答案
已选择的解决方案
I know you said you double checked the connections. But, triple check them. It's possible you just don't have the connector all the way in there. If that fails, I would guess you've purchased a part, with a bad cable. I've seen it happen. Play with the display assembly and see if that's likely the issue
这个答案有帮助吗?
得分 2
1条评论:
Thanks, ifixit sent me a new screen and it worked like a charm!
完成的
添加一条评论
添加你的答案
Jared Millirons 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 90
