RazerBlade Pro 17" (2014) electrical failure
Hello,
The first thing is that I notice that the battery wasn't not charging, then I remove the battery.
I notice that when I plug in the power cord it makes a electric click sound, and the indicator turns red for a micro second. I also notice that this also happen when I plug in a USB drive... I forgot to mention the BSOD that randomly shows up on windows 8.
The power cord does make the clicking sound, but the voltage and amp seems to be OK.
My guess is that the problem is the board where the USB and power cord goes.
Any idea?
Update since then,
I change the motherboard (found it on ebay for 120 U$), and I remove one of the RAM (it was causing the BSOD), but the battery is still not charging... For the rest it works fine now, I even add a SSD with a HP Pavilion dv6 3000 Series SATA Hard Drive Connector w Cable (5 U$), am I searching for a new battery 14.8V GMS-C40 961TA005F.
If anybody can help me find this battery I would appreciated a lot, or how to fix the battery, maybe the circuit board of the battery...
where can i find the part to repair
由 mike 完成的
