Printing slanted, not parallel to the top of pa
Hello all,
My printer started printing slanted. Printing on a blank page is mostly unnoticeable, but if printing labels the ones on the right are unusable as part of the printing will fall out of the labels bottom margin.
To illustrate the issue, if lets say I use top margin 1" and print an horizontal line, the left (start) of the line will be 1"from the top of the page, but the right (end) will be 1 1/4" from the top of the page.
Any idea what is causing the problem and how to fix it?
Thank you.
2条评论
Hi,
I'm wondering if you are having a paper feed problem. Here is a link to the User Manual, scroll down to p.71 which shows how to clean the paper pick up rollers.
http://download.brother.com/welcome/doc0... , Just a thought.
由 jayeff 完成的
I have the same problem on my MFC-9970CDW, but the printing on the left margin is perfect. I don't see how it could be a paper feed problem. Vertical lines are perfect. Horizontal lines are slanted.
由 Bob Johnson 完成的
