跳转到主内容
The Acer Aspire One model D225E is a 10.1-inch netbook that features an ultra-thin and lightweight design with a powerful battery making it ideal for everyday computing on the go. Also known as Acer Aspire One D255E-13639.
20 个问题 查看全部
问题已关闭
Why my netbook screen turns to red?
I have my netbook ACER DC22 DCkk which was I bought a few a years ago. When I opened it the screen turn into red with a frizzy lines of dashes. I don't know what's the problem with my netbook, should I replace my screen with a brand new one? or there is just a problem with the connection inside?.. I need your answer please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It sounds like it is a damaged connection of some sort.
If the the screen was the problem, you would have dead pixels or visible cracks in the image.
Look at the hinges of the device, often if they are damaged then that is where your locate the issue
I haven't had the best luck in working on this kinda problem, but anything is repairable if you want to put the effort into it.
Have you tried connecting to an outside display? Then you rule out a software glitch.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 105
