跳转到主内容
The JBL Charge 2+ made by JBL is the second generation of the JBL Charge brand.
The power button indicates that it's on but won't respond
The power button shows that the device is on but it won't respond to any of the buttons or when I tried charging it, what's wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
13条评论
Had the same problem and it was the resistor inside that came losse from the printboard. It is marked with 100 and you can see it if you remove the speaker on the right. I took a few more screws out and reconnected the resistor by soldering in two extra wires to make the electric connection with the printboard. And now I have sound again.
Will require some electrical skills.
完成的
thank you for the answer appreciate you sharing your knowledge.
完成的
I have the same problem but tried those methods given. Didn't work. The power on light is switched on permanently now and doesn't give any response at all.
完成的
Hi,
Can you turn it off? If not try a prolonged press on the power button - at least 10 seconds. If it still doesn't work how long have you had it? According to this link, there is a 2 year warranty on the product in the UK. You may wish to check that your warranty is still valid and that the same warranty period applies to where you are. http://uk.jbl.com/terms.html (para. 10.4) If it does contact Harman regarding a warranty claim on your device.
完成的
also me about the light please help mee
完成的
显示更多的8条评论
添加一条评论
3个答案
已选择的解决方案
Hi,
First, if you can, see if you hear anything if you connect a music source via a 3.5mm stereo cable into the input socket found between the Power In and Power out ports.
If so it proves your speaker works and you may have just lost the Bluetooth pairing to your music source (phone?). Have you tried re-pairing the Bluetooth connection?
If that doesn't work try pressing the Call (phone symbol) and the Vol+ button at the same time. Hopefully this will reset your device. You will have to re-pair any Bluetooth connections. Also try the cable connection again.
这个答案有帮助吗?
得分 3
4条评论:
This did not help to solve the problem. In my case the Power LED is turned on. The Phone LED is also turned on (looks like it is less bright than the Power LED). I've tried the Volume + and Phone combination without success.
完成的
Hi Eduardo Tavares,
Did you see the comment below regarding the possibility of a 2 year warranty on your device. It may be worthwhile to see if it applies to where you are and if you still qualify.
完成的
I just had the same problem. Solved it by removing /unplugging the battery and then putting it back in. All back to normal for now.
完成的
thanks to Jayson Van Camp
removing/unplugging the battery and then re-attaching worked for me.
完成的
添加一条评论
这个答案有帮助吗?
得分 2
3条评论:
How did u unplug it? Fromt he motherboard ?
完成的
Hi , and if I wait the battery low it will be solved ?
完成的
Hello, I have the same problem, could they solve it?
完成的
添加一条评论
Yes, unplug/plug battery. solved
这个答案有帮助吗?
得分 2
1条评论:
if you don't know how to unplug battery you can watch this video. https://www.youtube.com/watch?v=vWleIMuY...
完成的
添加一条评论
添加你的答案
Elisa Mejia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 48
总计 31,033
