跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
138 个问题 查看全部
Little stones in the steam wand
i get little hard flat stone like pieces that plug the steam wand and run out into the cup when I am priming the pump. I can easily un plug the wand, but I wonder what it is that is causing this and if it is unsafe to possibly be consuming these little prieces.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
These are pieces of scale, most likely calcium; they are formed when minerals in the water react with the metal of the boiler. Usually they adhere to the inside of the boiler but they can break free and plug the steam wand, among other things. Descaling the machine, and continuing to do so on a regular basis, should remedy this issue and prevent it from happening again. This is normal maintenance for any espresso machine.
这个答案有帮助吗?
得分 1
添加一条评论
I suggest not using it anymore. You best bet is to contact the company and tell them its posing as a health hazard and you want a replacement or you can technically sue them.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
cloden 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 115
