跳转到主内容
修复你的物品
维修的权力
商店
Sony Xperia Z3 Compact released in Sep. 2014.
93 个问题 查看全部
My Primary call mic is not working
Hi,
The Mic on my z3c is not working. I did a factory restore, even did the diagnostic and no cookie.
I disabled ok google and all that jazz. The phone is under warranty but the service center guys are refusing to consider it as the back panel is damaged and plan on charging me for the back panel and mic replacement which is completely unfair as the two had nothing to do with each other.
What do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
You need to solder a new mic on the mainboard.
这个答案有帮助吗?
得分 0
添加一条评论
Did you ever try to open the back panel by yourself? If yes, they would consider that you have broken the phone and made the phone warranty void. Since the mic is soldering on the motherboard, and it is hard to replace by DIY repair work, it is better to ask for the professional for help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Salman Dawood 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 726
