跳转到主内容
Acer Aspire V3-771G laptop. This is part of the 17.3" screen lineup that Acer offers.
14 个问题 查看全部
问题已关闭
Power-on failure, 5x blink led at power indicator
As of today i can't boot my acer v3-771 anymore.
power indicater blinks 5x orange light, but thats about all it does.
can't even hear any propeller or nothing, if it werent for the light i'd say ot was a dummy :/ anyone experience this? pitty , was fairly new, well taken care off ... cant' just let it go like that!
help be apreciated :P
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It could be a problem with static discharge , if so do the following.
1. Disconnect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds , then release for 30 sec and then hold down for another 30sec
4. Plug in power ,replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 dimm of ram, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
Hope this helps
这个答案有帮助吗?
得分 3
1条评论:
after i put it back together ill deffinatly try that, thanks for the input, and ill report back after i try
完成的
添加一条评论
Are you sure your power adapter is not faulty? Try asking a local repair shop if they could test your laptop with a known good power adapter, and see if the laptop boots.
这个答案有帮助吗?
得分 0
1条评论:
i got a friend that has the same laptop , well, 771G and his adapter is the same, i tried his on my laptop, and mine on his, and 2 x mine didnt start up and his did, so its not the adapter, someone said to me its a burned transistor but thats like a way to fast conclusion without further investigation imo
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 5,533
