跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
571 个问题 查看全部
Freezes and screen won't turn on after shutdown
Hi,
I'm having a lot of trouble with my iMac, and I can't figure out what's wrong with it. The problem is if I use the mac for a period of time, sometimes it can be almost a whole day other times it can be a hour. It all of the sudden freezes completely and the only way of getting it to work is to do a hard shutdown (holding the power button until it turns off).
But when I try to turn it on back on the the screen won't turn on. And I have to again do a hard shutdown, sometimes it takes around 5-6 times before the screen turns on. And if the problem occurred once and I try to use the Mac immediately after, it freezes within the first 10 minutes, and the whole procedure has to be repeated for another 10 minutes of usage. The only way to get it to not freeze up is if I don't use it for like a day, but that still only gives me around 3-4 hours before the problem occurs again.
I sent it to a repair shop to get it fixed, I figured that maybe its the hard disk. They ran some Apple test and told me it's not the hardware but the software causing the problem. So they factory restored it and gave it back to me. But it didn't fix the problem.
Any thoughts on what could be the cause of this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
First remove the frame and observe the diagnostic lights and tell us your findings. Next see if you can get an external monitor and the corresponding adapter.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Liam Spilberg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 356
