跳转到主内容
修复你的物品
维修的权力
商店
Manual Timer does not move
I found an Intermatic Master Control D-811 among my parents things & it hasn't been used for quite awhile. I set the timer & plugged in a lamp to see if it worked. When I turned it to the on position, the light worked, regardless of what time was set. When I turned it to the off position & plug the timer in the outlet, nothing happens, the timer doesn't move. It seems that whatever makes the timer move is not activated or moving. Can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
I have a similar Intermatic mechanical timer that is driven by a small clockwork motor. I discovered that the fine wire that comprises the motor winding had broken where it connected to one of the motor terminals.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
arch 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 9
总计 945
