How do I reattach the screen
I am replacing the screen assembly on my Microsoft Surface Pro. The breakdown instructions suggest using 3M double stick tape. I have found two different types, one is thin transparent double stick tape and the other is foam double stick tape, like you would use on cars. Can anyone tell me which one is the correct one to use?
Also, I may need to replace the bezel under the screen. Does anyone know where I can purchase one?
Update (12/22/2015)
Thanks for your reply. Now, I have another question. I know it is recommended to replace the lcd + digitizer together as an assembly, but how difficult is it to replace just the digitizer screen?
I've never attempted to replace just the digitizer. The display assembly is difficult enough to repair on these units, I imagine just the digitizer would be nearly impossible for someone with little experience.
由 RegencyTech 完成的
