跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
957 个问题 查看全部
The thick battery does not fit
I got the thick battery kit to replace in the ipod classic... and even looking at it, it seemed pretty thick.. there is no way I can snap the front of it together with it. How is it possible that it says it fits.. but does not?
The screen itself is bowing out a little bit, unless the battery has been swollen past the normal size.. Works great though for now. I think I'll have to get the thin battery... unless someone can tell me what I'm doing wrong. It seems pretty hard not to put it flat in the housing.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
The thick battery is for the 6th Gen 160gb that has the thicker hard drive and deeper back shell. Those batteries also fit the 5th Gen's that have the thicker 8mm hard drives. They won't fit in the thin classic.
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
3个回答
已选择的解决方案
I swapped out for the thin battery.. It was not too tight width wise, and I put a pad so it wouldn't rattle.. But it fit. I think the thick battery was swollen a bit.. But that's fine with the thin battery it seems to work the same as before.
这个答案有帮助吗?
按维修分数 1
添加一条评论
you very well could have a bad battery. compare it to another of the same type battery and you'll see its bloated. you most likely purchased a cheap battery from china.
这个答案有帮助吗?
按维修分数 0
评论:
I got it straight from I fix it.. :( serial number said it should fit.. But it's probably 4mm too thick. The last snap won't close and I can see the imprint bowing the screen. I emailed ifixit... At least the battery works :)
I have the same problem. First I got a thin battery and that was too wide, so i got the thick battery (both from fixit) and the case will not close.
添加一条评论
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
kwoks88 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 6
总计 174
