跳转到主内容
加入维修社区 - 创建账户
GoPro 的第七代相机,于 2012 年末发布。支持录制 1080p30 视频,防水深度达 197 英尺(约 60 米),并内置 Wi-Fi。
Can't turn on Gopro on battery after water damage. Works on USB.
Hi everyone,
A few months earlier, I got my Gopro immerged into pool water. I didn't see it immediately, but around 2 weeks later, when I tried to turn it on, I couldn't : no reaction from the camera, the screen kept off and I had no LED indicator.
However, the camera works finely when alimented by USB cable... The problem is not coming from my batterieS : I tested 3 different ones.
I'm suspecting a disease somewhere on the motherboard between the battery connector and one of the component because as I said, the camera has no problem on USB. How can I repair it to make it work again on battery ?
Thanks for the good work you're providing on this website.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
The expansion board might has some effect on the battery's charging and the usage of the battery.
Remove this part and see if the battery works fine. If so, replace.
GoPro Hero3 Silver Expansion Port
Replace the daughter board assembly with the GoPro port and the microSD card slot.图片
产品
$6.99
这个答案有帮助吗?
得分 0
添加一条评论
Any news on this?? Bump, my out put at the cameras battery ports were at 1.7v@.2A
oms @17.5
Update (03/17/2016)
So I try ed to replace this item and I get get positive feedback, the item turned on a lot faster,but I did not change the cable out, I did notice that it does need to be changed as well,and I have a live show of what happened when I turned it on that I could upload if anyonecares??
这个答案有帮助吗?
得分 0
1条评论:
upload if possible
完成的
添加一条评论
添加你的答案
Maxime Zackrisson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,327
