How I take out old HdDrive?
How i take out old Hard Drive?
这是一个好问题吗?
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
There is a guide for removing the bezel iMac Intel 24" EMC 2267 Front Bezel Replacement, but I haven't created the rest of the items for removing the HD. Basically it is the same as iMac Intel 20" EMC 2266更换硬盘指南 with some slight changes of the cable positions and screw lengths.
指南
难度:
中等
45 minutes
指南
难度:
中等
Unfortunately there isn't a guide for this model yet. Basically you have to remove the screen glass with the aid of two suction cups, it is held by magnets. Then you remove all the screws holding the front bezel, they are easyly spotted. Take care of the iSight camera and microphone cables on the top. Once you removed the bezel you are ready to remove the screen. It is held by four screws at each corner (if i recall right) and there are two cables to the logicboard you have to take care of. Then you'll see the innards of the machine in all it's glory ;-)
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 1,694
