跳转到主内容
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 个问题 查看全部
问题已关闭
I accidentally droped my phone in water, gave for repairing. Then a
I dropped my phone accidentally in water. Gave for repairing. After two days shopkeeper said phone is now useless, it cant b fixed,. Its been two weeks or more. But today i plugged the charger in it, a red light blinks from the top, which shows that it still has power in it. And i think it can be fix. Will you please suggest me now what should i do with it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hafsa Wajid I recommend that you do not try to charge, start or sync your phone. do not use it at all. Since you have had water damage, corrosion and residue from that can create a short circuit by you using your phone. I would start off by properly cleaning your phone. Use this guide and remove the board. Then clean everything with 90%+ isopropyl alcohol and a soft brush. Use this guide to clean your phone. It was written for an Apple iPhone but all the steps are pertinent to your phone as well. Once you have it cleaned, replace the battery. Anytime a device gets submerged it is important to replace the battery. It will fail if not replaced. After all that then try to charge and start your phone.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
Motorola Droid RAZR Motherboard图片
指南
Motorola Droid RAZR Motherboard Replacement
难度:
困难
这个答案有帮助吗?
得分 2
1条评论:
I would recommend this actually defiantly try this first!!!
完成的
添加一条评论
First i would try plugging it into a laptop and see if anything shows up on the laptop if it does and you can see the files i would defiantly say it can be fixed.
If still nothing try the following to do a hard reset THIS WILL DELETE ALL DATA!!!!!!
To Manually Reset
Turn off phone
Press Power key + "x" (on the hardware keyboard) to power on the phone and bring up the recovery screen.
Press Volume Up + Volume down key for 10 seconds then press and release the volume down key..
Using the volume keys scroll to Wipe data/factory reset
Press the center of 5-way navigation pad
Using the Volume keys, select Yes -- delete all user data
Using the Volume keys select Reboot system now
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 126
